RE: 10S Cell Pro charger
You might want to check the clips that hold the fuses are also tight. They sometimes get a little loose and that can lead to increased resistance. If the fuse is hotter than the charger, that is an early indicator the fuse holder is getting loose where the fuse pins plug in the clip.
Woodie
