ORIGINAL: RappyPilot Hi I have an Aurora 9 and I want to use 2 recevers in a fairly large plane for redundancy.
So if I plug the one Aileron/Elevator/Rudder into one reciver and the other aileron/elevator and throttle into another receiver will that work?
Regards, Marcel
Provided Aurora 9is linked and transmitting in "Normal"Mode, yes.
Optima Transceiver (RX) - Dual Redundant receivers -
note: both transceivers will see the same signal so individual ports can not be changed on each separate unit.
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid
Brownout
& Add Redundancy,
even one for each servo.
and more under Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
