RCU Forums - View Single Post - HELP with this support rod please
Old 09-02-2011 | 06:21 AM
mmcginn22
Default RE: HELP with this support rod please
Kit builder,
What you have said is exactly what i was trying to describe. The rod seems to go in all the way and then makes a noise like it is hitting a barrier. From this it is safe to assume the rod is in all the way.
However, when i look at the instructions, they point to a hole that holds a screw in the wing. My assumption is that when this screw comes out the rod can go in the rest of the way. Unfortunately after getting this screw out, that is not the case.
the first image shows the problem, with all the excess rod
the second shows where the hole is with the screw out
the third shows the directions and how this step is shown
thanks
ID:	1656430   Click image for larger version
ID:	1656431   Click image for larger version
