ORIGINAL: chuck l
I tore out the landing gear on my plane and am ready to recover the repaired area with Ultracote. I can cut out the Ultracote to the curved shape to follow the color scheme of the plane, however I'm concerned about the shape being distorted when it is ironed down. How do you apply the piece not lose its shape?
Chuck
One thing I learned is the importance of temp control. If you dont have a thermometer, set your iron and let it warm up. Once ready, splash a couple or drops of water on the irons bottom. If the water immediately evaporates, you might be too hot. Lower temp, let iron sit and cool, then try again. For me, Ive always found the best setting to be where the water drops sit for a couple of seconds or so before evaporating. Thats a good place to start for tacking/ironing down without shrinkage.
