Old 09-03-2011, 09:54 AM
kenh3497
kenh3497's Avatar
Default RE: 4C crank case drain
DUUUH, Never thought about adding a bit of material to the intake manifold. With that said maybe just solder in a nipple directly???? Nice solution to a messy problem. I would also assume you had to slightly change your mixture settings?
Has anybody used a "low" or "lower" oil content fuel. It seems to me this would be a possibility with ready supply of oil being reintroduced into the engine. Right now I'm burning heli fuel with a slightly higher content oil as it is the only fuel I have and I don't want to stock two different fuels. That will change as soon as it's gone. I've given up the heli's for the time being.
Thanks for the pictures!!
Ken
