ORIGINAL: WMB
Hey Dar, I may have all this wrong. The piston is pushed down by a force. The force is from the expanding air trapped above the piston. The air is expanding due to the massive temperature increase. The temp increase is caused by the burning of the fuel. If this is true, then the heat is the needed product to make the piston go down. So, does the energy in fuel itself do the work, expanding air due to heat, a combination of the two, something else?
Oil content? The car guys use less and there engines are run harder. Are we airplane guys ungrounded in engine tuning or is there another reason for more oil in our plane fuel? Never did understand this.
Thanks, MikeB
That is correct, Mike.
