RCU Forums - View Single Post - 8AWG wire to a Deans Connector?
Old 09-05-2011, 04:21 PM
MaxThrottle
Default RE: 8AWG wire to a Deans Connector?
It boggle the mind.... this repeating conversation.... look at the stardard plug you use on your wall. Now look at the 30 or 40amp plug on your stove or dryer. There is a standard of safe operation. Why is it necessary that some must push beyond this .....
Deans explains their connector is only as good as 12 AWG rating and are in the process of making larger connectors. If you are going to 8AWG why use a 12AWG rated connector?
