ORIGINAL: electricpete
I have inadvertantly switched on rx and telemetry while switched to wrong model, and lost the binding, is this normal.
Peter
You didn't lose bind. The only way a receiver and/or TM1000 loses its bind information is for it to be re-bound to something else. You may have to power cycle (as noted above) to get it to quickly re-connect to the transmitter, though. The rx did not lose bind.
A transmitter, otoh, erases its bind information as soon as you put it into bind mode. If you put the tx into bind mode, then you will definitely need to re-bind the rx for that model number again.
Andy
