RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltage Question
I'm using the exact same setup with the airtronics radio and recv and I had a problem only because I hooked up the plugs incorrectly. Dbl ck your hook up against the wiring diagram that came with the kill switch. I have mine hooked up to the gear channel
