RE: what to use instead of epoxy?
I use 'em all but thin CA works best with Gorilla Glue or epoxy over the top next after the CA dries, wetting the wood a bit helps gorilla glue adhere, on some harder, denser woods it doesn't soak in but just hardens on top giveing the "appeareance" of a glued joint
