RE: Rivets and panel lines in a 60 size AT-6?
The glue drop method of making rivets is good for round headed rivets that are raised above the surface of the metal, however, I think the AT-6 used flush rivets, didn't it. If so, a different technique would be required, eg, a short length of brass tubing of the correct size (from K & S) in a small soldering iron or wood burning iron would work well.
