RE: SIMLA BUILD THREAD
Duane.
I really haven't finished sanding the leading edge. So far I have only sanded the excess sheeting off the front of the LE. I started by sanding the laminated leading edge down to the rib pattern, which basically left a sharp pointed LE. Then when I sheeted the wing it left a LE of 3/16". At this point I could either leave it relatively sharp or I could round it some. What would you suggest?
