ORIGINAL: Eggman1965
ORIGINAL: setzer529
Got it fixed (thanks Gene)!<div></div><div>One of the wires to the battery case had broken off at the solder point. I had to strip it back, break out the iron, and reconnect it properly.</div><div></div><div>Now it's back to harassing pigeons in the park!</div>
Thanks Gene ?!?!?!
I thought I posted the " check the battery leads" advice! I don't get no respect, no respect at all.... (Rodney Dangerfield)
Mike
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: small"><span style="font-family: Times New Roman"><span style="mso-bidi-font-size: 10.0pt">Hi Mike (Egghead1965) and YES you did have the right answer when it came to the issue with his tank, you nailed it fellow tanker. Great Job! Actually everyone that offered ideas in fixing his tank including Shenlonco had excellent advice.</span></span></span><span style="font-size: 12pt; mso-bidi-font-size: 10.0pt"><o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: small"><span style="font-family: Times New Roman"><span style="mso-bidi-font-size: 10.0pt"></span></span></span><span style="font-size: 12pt; mso-bidi-font-size: 10.0pt"><o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: small"><span style="font-family: Times New Roman"><span style="mso-bidi-font-size: 10.0pt">I think what a lot of people may miss is that there are a lot of new tankers on this forum that have never opened up or fixed a RC tank before. So we can all write the correct advice, but new tankers reading this great advice may not understand entirely because he or she may not have the experience with either electronics, wiring, soldering, opening up tanks and so on.</span></span></span><span style="font-size: 12pt; mso-bidi-font-size: 10.0pt"><o
></o
></o
></span></p><p class="MsoBodyText" style="margin: 0in 0in 0pt"><span style="font-size: small"><span style="font-family: Times New Roman">When this is the case, some people just need for someone to talk with him on the phone and walk him or her through the process in finding out what the problem may be and I was more than happy to help Setzer529 with just that. Luckily Setzer529 knew how to solder and was able to fix his tank. Great Job!</span></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: small"><span style="font-family: Times New Roman"><span style="mso-bidi-font-size: 10.0pt"></span></span></span><span style="font-size: 12pt; mso-bidi-font-size: 10.0pt"><o
></o
></span></p><span style="font-size: small"><span style="font-family: Times New Roman"><span style="mso-bidi-font-size: 10.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">New Tankers or Advanced Tankers, as one, WE ARE ALL FELLOW TANKERS!!!!!!!</span>
Gene</span></span>
