RE: A4 Skyhawk build
I'm glad you got yours! I can now follow along when you pass me! A couple of notes.....
1. The flap servos in mine went in a ply mount pre installed. I used jr8411s. You will have to sand, esp the glue on the wingskin to get them in. Also I put a small servo horn facing straight down so the linkage doesn't bind with the scale "pod" cover.
2. The Stab also has a pre installed ply plate and I installed the servos "face down" (towards the stab tip), you will need small servos Jr3421 is what I used.
The airelons are pretty straight foward. I'm sure you'll pass me soon enough I build slow! I am looking to possibly change the rudder set up. Let me know what you decide.
Peter
