Well, quite good weather today,and even thouh im not finished yet, i used the opetunity to take some test flights.
Had 2 flights, until one of the wing strut bolts loosened, and I didn`t have any tools with me to fasten it again.
Ill give them all lock tite now.
It flew well with the CG at 45mm on the lower wing balanced upside down.
The manual is confusing. It shows the CG on the top wing, but the text describes it at the 45mm from the leading edge of the wing on the fusealge.
Elevator and aileron are quite numb....so I gave it double up on the throws than the manual suggests.
Rudder is very effective.
This is not realy a good plane for a beginner, as it is not that easy to fly.
My first takeoff failed
I gunned the throttle, and it just nosed over.
You have to gently increase power, and feed in just enough elevator to keep it level....so it does not take off too early, or too little, and it noses over.
Once in the air, you have to use alot of rudder in coordinatin with the ailerons to get it around nicely.
Its a very stable plane, but wind gusts do thorw it around a bit. and you can deffinaly feel a crosswind.
But it looks fantastic in the air, and you realy go back to the 30`s eara
