RE: Kangke Waco Biplane
Well, finally just about done with this build. I havent really been rushing to get it done since it has been 100+ degrees for about 2 months straight here. Just have to mount the cowl and add the gear stiffeners. Just roughly checking the CG at the top wing joiner strap(right at 4" behind the leading edge) It looks like I may have to add about a pound of lead to get it to balance.I have everything as far forward as possible also. The elevator servos are in the tail, the rudder servo is in the middle and everything else but the reciever is either under the M struts or forward.
