RE: Phoenix Tiger Moth .40
The 45mm CG is just at the LE of the aft cabane, with an empty fuel tank.
Im probably a little nose heavy at the moment.
Installing the 2 pilots will move CG slightly aft, and ill se how it flys there.
Just gave them a little makeover.
I added 7mm under them, as they sit too low in the cockpit, as you can see in the last 2 pics of the stock moth.
You can also see it is the old version which does not have the remoavable upper hatch on the fuselage as I have.
I also trimmed the windows down in size.
