ORIGINAL: Oberst
True. A good Sport Scale ARF I would pick the PTS Mustang and just remove the PTS stuff off of it. Once you have a little bit of building or assembly under your belt, then I would add the E-flite Retracts.
Pete
The T-34 is a PTS, so quite familiar with the droops, makes it a good stable flyer once Itrimmed it out. If I wanted a quick build the P-51 PTS would make a good plane, no doubt about it. Especially since it comes with the motor already to run, no breakin or tuning needed, just fire it up, adjust for temp and off it goes. I'm looking for a kit build, something to burn up the winter hours.
