RE: Vendetta spur gear pitch?
The Vendetta pinion / spur gear pitch is .6 module, which is otherwise known as 48 pitch metric. The Robinson Racing pinions, part numbers 1112 - 1124 will work fine. American standard 48 pitch, which is common, is close but there's clearly a mesh problem with them if used on the Vendettas.
