RCU Forums - View Single Post - Getting prepared.
Old 09-14-2011 | 04:54 AM
luciuswillson
Default RE: Getting prepared.
My original post I was wondering if I could use titebond on the spar dubblers or use epoxy like the manual states.
Also is elmars wood good or gorilla wood glue the same as titebond?
ORIGINAL: smithcreek
ORIGINAL: Gray Beard
There are several places I wouldn't use wood glue in place of epoxy.
If you are 100% sure you have excellent wood/wood contact then wood glue or thick CA is fine, but there are some places where you don't or don't know if you do, like gluing in a dihedral brace on a wing with the center section already sheeted. Epoxy will bridge a small gap and be very strong, wood glue will not.
