RCU Forums - View Single Post - Getting prepared.
Old 09-14-2011 | 07:38 AM
makmov
Default RE: Getting prepared.
TiteBond II
<table border="0" cellspacing="0" cellpadding="0" width="611"> <tbody> <tr valign="top"> <td width="105"><font size="2" face="Arial">Physical Properties (Typical)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="486"> <tbody> <tr> <td width="240"><font size="1" face="Arial">Type</font><font color="#666666" size="1" face="Arial">Cross-linking polyvinyl acetate</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Calculated VOC: </font><font color="#666666" size="1" face="Arial">5.5 g/L</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">State</font><font color="#666666" size="1" face="Arial">Liquid</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Weight/gallon </font><font color="#666666" size="1" face="Arial">9.1 lbs.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Color</font><font color="#666666" size="1" face="Arial">Honey cream</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Chalk temperature*</font><font color="#666666" size="1" face="Arial">Approx. 55&deg;F.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Dried film</font><font color="#666666" size="1" face="Arial">Translucent, yellow</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Flashpoint </font><font color="#666666" size="1" face="Arial">&gt;200&deg;F.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Solids </font><font color="#666666" size="1" face="Arial">48%</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Freeze/thaw stability </font><font color="#666666" size="1" face="Arial">Stable</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Viscosity </font><font color="#666666" size="1" face="Arial">4,000 cps</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">pH </font><font color="#666666" size="1" face="Arial">3.0</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Storage life </font><font color="#666666" size="1" face="Arial">12 months in tightly closed containers at 75&deg;F.</font></td> <td width="6"></td> </tr> </tbody> </table> <font size="1" face="Arial">*Chalk temperature indicates the lowest recommended temperature at which the glue, air and materials can be during application, to assure a good bond.</font></td> </tr> <tr bgcolor="#cccc99"> <td bgcolor="#ffffff" width="15"></td> <td width="596" colspan="3"></td> </tr> <tr valign="top"> <td width="15"></td> <td width="105"><font size="2" face="Arial">Application Guidelines</font></td> <td width="5"></td> <td width="486"><font size="1" face="Arial">Application temperature</font><font color="#666666" size="1" face="Arial">Above 55&deg;F.</font>
<font size="1" face="Arial">Open assembly time</font><font color="#666666" size="1" face="Arial">5 minutes (70&deg;F./50%RH)</font>
<font size="1" face="Arial">Total assembly time</font><font color="#666666" size="1" face="Arial">10-15 minutes (70&deg;F./50%RH)</font>
<font size="1" face="Arial">Minimum required spread</font><font color="#666666" size="1" face="Arial">Approximately 6 mils or 250 square feet per gallon</font>
<font size="1" face="Arial">Required clamping pressure </font><font color="#666666" size="1" face="Arial">Enough to bring joints tightly together (generally, 100-150 psi for softwoods, 125-175 psi for medium woods and 175-250 psi for hardwoods)</font>
<font size="1" face="Arial">Methods of application </font><font color="#666666" size="1" face="Arial">Plastic bottles for fine applications; glue may also be spread with a roller spreader or brush.</font>
<font size="1" face="Arial">Cleanup </font><font color="#666666" size="1" face="Arial">Damp cloth while glue is wet. Scrape off and sand dried excess.</font>
</td> </tr> <tr bgcolor="#cccc99"> <td bgcolor="#ffffff" width="15"></td> <td width="596" colspan="3"></td> </tr> <tr valign="top"> <td width="15"></td> <td width="105"><font size="2" face="Arial">Bond Strength ASTM D-905
(On Hard Maple)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="400"> <tbody> <tr> <td width="200"><font size="1" face="Arial">Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">Strength psi</font></td> <td width="100" align="center"><font size="1" face="Arial">% Wood Failure</font></td> </tr> <tr bgcolor="#000000"> <td width="400" colspan="3"></td> </tr> <tr> <td width="200"><font size="1" face="Arial">Room Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">3,750</font></td> <td width="100" align="center"><font size="1" face="Arial">72</font></td> </tr> <tr> <td width="200"><font size="1" face="Arial">150&deg;F. Overnight</font></td> <td width="100" align="center"><font size="1" face="Arial">1,750</font></td> <td width="100" align="center"><font size="1" face="Arial">6</font></td> </tr> </tbody> </table> </td> </tr> </tbody></table>
TiteBond III
<table border="0" cellspacing="0" cellpadding="0" width="611"> <tbody> <tr valign="top"> <td width="105"><font size="2" face="Arial">Physical Properties (Typical)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="486"> <tbody> <tr> <td width="240"><font size="1" face="Arial">Type</font><font color="#666666" size="1" face="Arial">Advanced Proprietary Polymer</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Calculated VOC: </font><font color="#666666" size="1" face="Arial">5.6 g/L</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">State</font><font color="#666666" size="1" face="Arial">Liquid</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Weight/gallon</font><font color="#666666" size="1" face="Arial">9.22 lbs</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Color</font><font color="#666666" size="1" face="Arial">Tan</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Chalk temperature*</font><font color="#666666" size="1" face="Arial">Approx. 47&deg;F</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Dried film</font><font color="#666666" size="1" face="Arial">Light brown</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Flashpoint</font><font color="#666666" size="1" face="Arial">&gt;200&deg;F.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Solids</font><font color="#666666" size="1" face="Arial">52%</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Freeze/thaw stability</font><font color="#666666" size="1" face="Arial">Stable</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Viscosity</font><font color="#666666" size="1" face="Arial">4,200 cps</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">pH</font><font color="#666666" size="1" face="Arial">2.5</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Storage life</font><font color="#666666" size="1" face="Arial">12 months in tightly closed containers below 75&deg;F.</font></td> <td width="6"></td> </tr> </tbody> </table> <font size="1" face="Arial">*Chalk temperature indicates the lowest recommended temperature at which the glue, air and materials can be during application, to assure a good bond.</font></td> </tr> <tr bgcolor="#cccc99"> <td bgcolor="#ffffff" width="15"></td> <td width="596" colspan="3"></td> </tr> <tr valign="top"> <td width="15"></td> <td width="105"><font size="2" face="Arial">Application Guidelines</font></td> <td width="5"></td> <td width="486"><font size="1" face="Arial">Application temperature</font><font color="#666666" size="1" face="Arial">Above 47&deg;F.</font>
<font size="1" face="Arial">Open assembly time</font><font color="#666666" size="1" face="Arial">10 minutes (70&deg;F./50%RH)</font>
<font size="1" face="Arial">Total assembly time</font><font color="#666666" size="1" face="Arial">20-25minutes (70&deg;F./50%RH)</font>
Patent Pending
</font><font color="#666666" size="1" face="Arial"></font>
(On Hard Maple)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="400"> <tbody> <tr> <td width="200"><font size="1" face="Arial">Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">Strength psi</font></td> <td width="100" align="center"><font size="1" face="Arial">% Wood Failure</font></td> </tr> <tr bgcolor="#000000"> <td width="400" colspan="3"></td> </tr> <tr> <td width="200"><font size="1" face="Arial">Room Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">4000</font></td> <td width="100" align="center"><font size="1" face="Arial">57</font></td> </tr> <tr> <td width="200"><font size="1" face="Arial"></font></td> </tr> </tbody> </table> </td> </tr> </tbody></table>
Original TiteBond
<table border="0" cellspacing="0" cellpadding="0" width="611"> <tbody> <tr valign="top"> <td width="105"><font size="2" face="Arial">Physical Properties (Typical)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="486"> <tbody> <tr> <td width="240"><font size="1" face="Arial">Type</font><font color="#666666" size="1" face="Arial">Aliphatic resin emulsion</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Calculated VOC:</font><font color="#666666" size="1" face="Arial">10.7 g/L</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">State</font><font color="#666666" size="1" face="Arial">Liquid</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Weight/gallon </font><font color="#666666" size="1" face="Arial">9.2 lbs.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Color</font><font color="#666666" size="1" face="Arial">Yellow</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Chalk temperature*</font><font color="#666666" size="1" face="Arial">Approx. 50&deg;F.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Dried film</font><font color="#666666" size="1" face="Arial">Translucent</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Flashpoint </font><font color="#666666" size="1" face="Arial">&gt;200&deg;F.</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Solids </font><font color="#666666" size="1" face="Arial">46%</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">Freeze/thaw stability </font><font color="#666666" size="1" face="Arial">Stable</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Viscosity </font><font color="#666666" size="1" face="Arial">3,200 cps</font></td> <td width="6"></td> <td width="240"><font size="1" face="Arial">pH </font><font color="#666666" size="1" face="Arial">4.6</font></td> </tr> <tr> <td width="240"><font size="1" face="Arial">Storage life </font><font color="#666666" size="1" face="Arial">12 months in tightly closed containers at 75&deg;F</font></td> <td width="6"></td> </tr> </tbody> </table> <font size="1" face="Arial">*Chalk temperature indicates the lowest recommended temperature at which the glue, air and materials
can be during application, to assure a good bond.</font></td> </tr> <tr bgcolor="#cccc99"> <td bgcolor="#ffffff" width="15"></td> <td width="596" colspan="3"></td> </tr> <tr valign="top"> <td width="15"></td> <td width="105"><font size="2" face="Arial">Application Guidelines</font></td> <td width="5"></td> <td width="486"><font size="1" face="Arial">Application temperature</font><font color="#666666" size="1" face="Arial">Above 50&deg;F.</font>
<font size="1" face="Arial">Minimum required spread </font><font color="#666666" size="1" face="Arial">Approximately 6 mils or 250 square feet per gallon</font>
(On Hard Maple)</font></td> <td width="5"></td> <td width="486"> <table border="0" cellspacing="0" cellpadding="0" width="400"> <tbody> <tr> <td width="200"><font size="1" face="Arial">Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">Strength psi</font></td> <td width="100" align="center"><font size="1" face="Arial">% Wood Failure</font></td> </tr> <tr bgcolor="#000000"> <td width="400" colspan="3"></td> </tr> <tr> <td width="200"><font size="1" face="Arial">Room Temperature</font></td> <td width="100" align="center"><font size="1" face="Arial">3,600</font></td> <td width="100" align="center"><font size="1" face="Arial">77</font></td> </tr> <tr> <td width="200"><font size="1" face="Arial">150&deg;F. Overnight</font></td> <td width="100" align="center"><font size="1" face="Arial">1,600</font></td> <td width="100" align="center"><font size="1" face="Arial">10</font></td> </tr> </tbody> </table> </td> </tr> </tbody></table>
I use original TiteBond andTiteBond II, and avoid super glues like the plague.
Generally there is a reason for using epoxy though, and I don't use an Alphatic resin in place of epoxy.
