Blake,
Nice looking Kaos!
Is that paint on the fuse or is it all Monokote (I take it the wing is MK judging by the
light kick off it)?
Looks like an older gold head FSR up front too. Nice engines.
Congrats on your win!
David.
P.S. While you appear to have equal building skills to your pilot skills, I'd recommend going for a foam core wing and stab design. I'm not sure if the compensator kit you have has such surfaces. If you want an easy fuse to
build, go with Don's (Frequent Flyer handle) glass fuse Atlas
It does not have an integral fin but he can probably provide you with a fin/rudder core as well as the wing/stab cores. A wood Deception fuse probably goes together as quickly as the prep work required get a glass fuse setup for engine and radio. But then, if you like paint, the glass fuse will prep faster than the wood fuse. Just some other thoughts...
