RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 10-01-2011 | 01:52 PM
  #514
billberry189
Default RE: SIMLA BUILD THREAD
Richard,
No. But then I think I may have added a small block to the very end of the fuselage since I chose to close it in. I typically leave room for the fuel lines to come through the center of the mount and around the engine.I would not be able to do that if I installed the engine as far back on the mount as it would go. The end point for the nose is somewhat adjustable. Make it longer, add a block. Make shorter, saw it off. Easy!
Bill
PS- Now that I think about it the fuselage nose is one of the few places where creative adjustments can be made without drasticallyaltering the overall scheme of things.
Bye Now
PPS- Theoretically, as you move the engine forward you could reduce the diameter of the spinner say 1/4" and get a sleaker/ slipprier front profile, as well asmoving the CG forward to offset any extra tail feather weight. Just a thought.
