RCU Forums - View Single Post - Help !! braking problem
Old 10-02-2011 | 01:54 AM
icedude1989
Default RE: Help !! braking problem
what about your esc?? did you change the esc as well or just the motor?? if you havent changed the esc then maybe it is a compatibility issue between motor and esc?? or maybe the esc you have now on the redcat is not set up properly to read 'idle, forward, reverse' positions.
