RE: How do I install a hardened diff gear on a Losi Speed-T?
Ok... this thread is a bit confusing. But you should still be able to make the ball diff gear work with the speed-t. The stock speed-t diff gear is actually a ball diff with locking rings that grip it where the diff balls pop in. You should still be able to use these plastic rings with the RRP gear.
