RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 10-02-2011 | 06:37 PM
  #518
kingaltair
Default RE: SIMLA BUILD THREAD
ORIGINAL: billberry189
Painting the firewall before it is installed might be the way to do it.
I'm doing a little finish work on the fuselage hatches this weekend. I also think I'm going to prime the fuselage, guide coat it, and block it one more time before I paint it. Hopefully I'll have some color on it this week.
Bill
Just my 2 cents, but I would not paint the firewall before installation, because I think you will possibly get a stronger and better adherance if the glue joint for the firewall joins a more porous non-painted surface. It may not matter, (especially iof you've already done it). I usually polyurethane the firewall and engine compartment later.
Regarding the hatches, I have some photos of the double hatch area on the prototype. As I said earlier, Kevin had two hatches as well, but devised a method where he only uses one screw for BOTH hatches. (Make sure that one is tightened down well).
ID:	1669185   Click image for larger version
ID:	1669186   Click image for larger version
ID:	1669187   Click image for larger version
ID:	1669188   Click image for larger version
