RE: back to back sequence
Technically, if you finish the first sequence and encounter problems with the plane (mechanical failure etc.) and you have not started the second sequence, you can land and attempt a fix. If you are successful and have your palne ready you can get at the end of the flight order and fly the second sequence.
Flight direction is at the discretion of the pilot and is usually determined by wind direction.
