TDC Pinch getting "worse"?
I purchased a 25FX for Q25 racing (so I guess that voids the warranty). I broke the engine in using PowerMaster 10/22 and an APC 8/5 prop for 32oz (8 4oz tank runs). The engine performed well spinning an APC 8/6 at just over 16K. I had run another 6 4oz tanks of 10% PowerMaster flight trimming never letting the engine get hot or run too lean.
On to race day...
The CD supplied PowerMaster 15% nitro 18% oil for the race. The first tank of fuel (practice laps), the engine ran as it had before with good power. The first race, the engine seemed to be down on power slightly but I chalked it up to a fresh engine vs well run in engines used by the rest of the competitors. The engine continued to loose power race by race. I finally withdrew since I was no where near competitive. I tached my engine and was surprised that I could not get over 15K with the APC 8/6 and 15% fuel since I had been getting well over 1000 more RPM 3 tanks earlier.
Inspecting my engine, I noticed that it is very difficult to turn the prop over at TDC. The piston squeeks and clicks as it's brought past TDC. Like a good ABC engine is supposed to, but 5 times worse. It does this even without a glow plug. I took the engine apart to see if I could find anything wrong with it, but I can not see anything visually. The piston and sleeve look very good. The top of the piston has some light brown staining on the top toward the exhaust port as you would expect.
One interesting thing I noticed is if the head bolts are just slightly loosened, the engine turns over easily. Snug the bolts down and the engine is VERY difficult to turn over -with a prop and without a glow plug.
Sooo what made the "pinch" worse? I know this may be impossible to determine without physically inspecting the engine.
