super tigre g20 ring replacement
I have a made in china ST G20 that I want to replace the ring. The bore size is 1.280". Do I need to pull the cylinder out to get the piston/conrod out to replace the ring and if so how do you get the cylinder out? I am used to having a cyliner with a flange on the top that can be used to pry out the sleeve with a small screwdriver. Any help would be great. Also what do I use for allignment when putting the sleeve back in the block?
thanks,
chris
