RE: Carbon Fiber Push Rods ??
Jeff, now that's is a great idea!! So are you just using CF arrow shafts
and If so what size are they? thanks so much for the pictures, worth
a thousand words. So from what I am seeing , wrap threaded wire to the
point that the threaded rod just slips in CA it and your done. how far into
the CB shaft are you setting the threaded rod?
Again THANKS!
I was thinking after the CA is done why not add just a dab of JB weld on the end for
extra safety? :-)
Jeff
