RCU Forums - View Single Post - Redcat Lightning
Old 10-16-2011 | 11:05 AM
nitrosportsandrunner's Avatar
Default RE: Redcat Lightning
ORIGINAL: SacMan31
What other brand parts will fit the lightning exp? And are the lightning ep drift and epx pro the same parts just with a different motor? Are the epx and drift parts interchangeable?
id have to check on the drift and epx pro versions. i know the epx pro had metal diff gears, im not certain the drift version does.
other than that, its just the tires and motor/esc
you can use just about any brand body, any brand wheel(that is 12mm hex)
you can use other shocks of the same length.
