Old 10-19-2011, 10:36 AM
91zulu
Default RE: Favorite G62 props
From experience the 23x8 works great. I found on 2 airframes this to be true. Ziroli Stuka and Meister ME 109. Both planes pulled well and I could do a descent loop. Antique is right, from trying different brands and sizes the 23x8 worked the best. On a TA 152 it should have it zooming. Especially if the engine is already broken in and not damaged. What some folks fail to mention is whether their engine is new or well broken with at least 5 gallons through it. It makes a big difference. A new G62 will not out perform a good broken in one.
Stock for stock that is. Just make sure the prop is well balanced. As for Zingers, you do have to take a careful look at which one you use. Some are very bad.
