RCU Forums - View Single Post - Chainging a EQ 8E into a AS 8E
Old 10-19-2011 | 06:04 PM
formula87's Avatar
formula87
Default RE: Chainging a EQ 8E into a AS 8E
ORIGINAL: XtrmTJ
OK, just got to run my SCT 8E (former EQ 8E) at the coast(sand). Ran it around for 5 to 10 minutes, a couple small jumps, a couple high speed passes. Brass motor gear strips out on me. Mesh too tight / too loose? Sand ? Oh yea, I am now running a steel spur gear. This was the 15t brass motor gear. Any armchair qb'ing here ? heeelp... lol
Smitty
Mesh Mesh Mesh.......... can't say more about getting the mesh right......I ran my EQ now BD convert and never any probs with stock pinion and spur............ I like the stock spur............ quiet and cheap. Go back to stock pinion and spur and don't worry about theold paperbetween the pinion and spur trick...........you just want a "tick"of play ............hmmmm.....I may do avid on that................ never looked back after figured thatout....................
