ORIGINAL: TheRickster
Just another point of interest.. At full travel you will be inducing uneven elevator travel with the servo mounted as it is. As the servo arm moves through it's arc of motion it will put more travel into one pushrod than the other.. If you lay the servo arm on it's side then it will be on the same axis as the elevator and will retain even travel through it's arc..
Rick
Hi Rick,
Do you mean that the whole servo should be mounted on its side?
