RCU Forums - View Single Post - Soaking an engine in antifreeze in a crock
Old 10-29-2011 | 01:49 PM
  #31
HighPlains
Default RE: Soaking an engine in antifreeze in a crock
A lot of people clean their engines due to the external appearance. But you should examine the interior of the engine from time to time. For instance heavy deposits of varnish on the piston walls or sleeve can cause excessive drag on the engine which will present itself as an engine that has difficultly maintaining a reliable idle.
