RE: 72
Hi Mick looks good mate,if i were you id consider having the pipes coated to keep the heat inside the hull to a minimum as steel pipes give off a lot of heat.Im wondering how the mod you did to the hull for the carbs will effect the handling of the boat as the tunnel has now changed somewhat,might not be an issue just a thought.
Mart
