RE: ***CUB BROTHERHOOD***
Here are pictures of how I split the Hangar 9 80" Cub cowling. I used two small nylon landing gear straps for the front mounts with small servo screws and regular screws at the firewall. The dummy cylinders are attached to the lower portion of the cowl.
The old BUSA Cub just has a big slot cut in it in line with the cylinder so with the prop removed it just slides straight on.
Jaybird
