RCU Forums - View Single Post - Springer Build
Old 11-04-2011 | 07:30 AM
Apismelifera's Avatar
Apismelifera
Default RE: Springer Build
Basically any value from 0.1 uf to .01 uf will work. Ceramic disc capacitors have good high frequency characteristics and they're inexpensive. Get ones that are rated at 50 volts or higher.
You can also check some the hobby stores, where you can but a set of motor caps. Or go to radio shack.
You wire them like this:
