RE: JTEC CANISTER DEVELOPMENT
Kevin,
I appreciate the information....With your cannisters are you saying you will get the same rpm out them as you get in the stock DLE muffler, but it will quiet the motor down. If that is correct, that would be the ticket....I am worried about losing RPM cause I need all I can get. What is the weight of the cannister....how much heavier is the cannister as compared to one of your small pitts muffler for a DLE55. I have flown with a RE2 and the pipes seem to be a bit peaky and they come on at the tail end of the powerband.
Brian
