RE: TT 40Pro endplay?
Hi!
It,s vital that you get a lose fit bearing (C3 or C4)! Not an ordinary standard steel bearing! C3 or C4 means that the play between the balls and the inner and outer surface is less than a standard bearing...that means that the bearing produce less friction then a standard bearing.
