ORIGINAL: WacoNut
You will love how the plane fly's.
I noticed you have the cardboard tube for the tail servo leads attached to the bottom of the fuse top formers. Is this in the manual or just a preference change by you? The reason I am asking is I built one of the 1st kits and the manual had the tube mounted in the bottom of the fuse and I moved it to the top to allow more room for the rudder pull/pull and suggested this change to AMR.
All in all it was an excellent build and it is rock solid in the air.
Later!!
Anthony
I talked to you in the spring, AMR still wants it on the bottom, I took your advice and moved it to the top. I also reinforced the tail area. I can post a better picture if you want to see it. I'm planning to use Hitec HS-645 thru out. I see they want a 300 oz monster for the rudder. Did you do that or go with a smaller servo for the rudder?
Randy
