Replacing CA hinges
I just removed a rudder from my pattern plane and was going to replace the broken CA hinges. The wood at the hinges has been soaked with CA with the last hinge. Can I replace the hinge in the same spot and still have the same strength, or should I move the new hinges to a new locations? I haven't tried to remove the old hinge halves yet, any hints on removing them?
Thanks, Mitch
