ORIGINAL: vertical grimmace
Heres a pic of the muffler system I just orderd for my G62. Also a lay down cab assembly to make the whole engine 1'' smaller. This should hide almost the whole thing in my TA 152. Here is a SIsT D model with this engine muffler combo installed. The can does give a performance boost I am told.
Unfortunately the G-62 will not fit into a 1/5 scale D9 or TA-152 without cutting a large hole for the head. As said in previous post the SisT D9 was designed for the G-45 and fits quite well, some have been able to fit and position so that only the spark plug boot slightly protrudes from the cowl flaps. I'm sure the ESM D9 would be the same as the dimensions are are pretty much the same.
