ORIGINAL: n8622t
hey whistling death where can you convert a G26 to an EI for $70[X(] I would be very interested in that
Jimmy
It's done with a Rcexl DIY kit sold by several venders that takes about 1/2 an hour to set up. The timing doesn't need to be adjusted so is literally plug & play. This is true of all the Zenoah engines and conversion kits. You either need to use a puller to get the flywheel off or heat it gently with a torch.
[link=http://www.agaperacingandhobby.com/viewitem.php?productid=212]Agape Racing and Hobby[/link]
[link=http://www.rcextremepower.net/ignitions.html]RC Extreme Power[/link] Scroll down to the middle of the page.
[link=http://www.valleyviewrc.com/estore/rcexl-zenoah-g26-single-cylinder-ignition.html]Valley View RC[/link]
