RCU Forums - View Single Post - Fiberglassing question
Old 12-01-2011 | 02:43 PM
skeeter_ca's Avatar
skeeter_ca
Default RE: Fiberglassing question
ORIGINAL: Avaiojet
ORIGINAL: LargeScale88
I do like the cloth, such as stits, but I like fiberglass because it gets rock hard and it can get banged around without punching a hole in it like cloth.
I know this thread is about cloth but heres how I fill the weave when i fiberglass:
1: lay cloth down, saturate in resin, use a credit card (or similiar) and push all the excess resin out, wipe up, and wait till it cures
2: SAND!
3: Put another layer of JUST resin, push excess out with credit card
4: SAND!
5: repeate with adding resin and sanding till weave is filled
It is a more time consuming process, but its much easier to fill the weave putting more layers of only resin on than bondo like some people do, and gives a good surface to sand.
So to end it, I think it depends on the airplane. A warbird I would fiberglass for sure, but a sport plane and similiar, I would use stits cloth.
Jason
Jason,
I've never glassed like that. Where did you learn that?
Charles
Sounds like the way full-scale fiberglass planes are done. No bondo or filler just fiberglass & resin and more resin as needed during sanding.
skeeter
