RE: ***CUB BROTHERHOOD***
thanks for the photos. they'll help a lot. i've already been browsing the manual for the sig cub kits as well. the only issue i see having with doing mine, is that i already have the horizontal stab installed, so i will be using paper to make templates for each section before rough cutting the fabric. it's either that or i do the top from the side stringers up, each half, then do each side from there down. does it matter 'scale wise' where the pinked tape goes on the fuselage? i see from the photos above where it was installed, but i haven't seen actual aircraft photos of where it is, and can't see well enough on any aircraft on airliners.net. did you use some scale outline for applying it?
