RCU Forums - View Single Post - servo arm length vs torque rating
Old 12-04-2011, 02:28 PM
pimmnz
Default RE: servo arm length vs torque rating
Rodney is right, you will loose no torque whatever length arm you use, but Torque is a product of a Force times a Distance. (T=FxD).
So for your 200 oz.in servo, that is 200 oz of force at a distance of 1 inch from the axis, will be a force of 100 oz at 2", 50 oz at 4" etc. Or 400 oz at 1/2 inch. etc. This is the force delivered then to the controlled surface horn. As to how you arrange the arm/horn length to get the surface movement you want that is entirely up to the operator, but using 100% of the servo movement is always preferable, modern computer radios have not removed the need to set up the mechanical part of the system with the usual care.
Evan, WB #12.
