RE: DA100-Ran perfect until today-went rough midflight
RC EXL ignitions now come with a sensor mount that requires no drilling, the legs are slotted way longer...You have to check the magnet in the hub before you put the sensor in the bracket...the south pole of the magnet triggers the sensor..you can turn the sensor over in the bracket if the North pole is facing up...
