ORIGINAL: cumminspower5.9
well to answer most everyone as of now starting from the top.
-yes, sheo, this does happen every winter.
-hedgehog, 2 psi below max doesn't mean it's going to blow out the tire. max is just max recommended psi, ive seen tires go above that for years.
-proanti and dave, i had only replaced the paper filter with the K&N. i don't have the actual cold air intake on this car. i know it would be pointless. i let the car warm up every morning.
i drive like an old man as well because i know it uses more fuel. plus why not get the most out of the expensive liquid. i try not to let the engine get above 3200 rpm.
Max recommended tire pressure is different than max tire pressure. You never clarified which.
