RCU Forums - View Single Post - Fiberglassing question
Old 12-10-2011 | 07:27 AM
Props4ever
Default RE: Fiberglassing question
ORIGINAL: LargeScale88
I do like the cloth, such as stits, but I like fiberglass because it gets rock hard and it can get banged around without punching a hole in it like cloth.
I know this thread is about cloth but heres how I fill the weave when i fiberglass:
1: lay cloth down, saturate in resin, use a credit card (or similiar) and push all the excess resin out, wipe up, and wait till it cures
2: SAND!
3: Put another layer of JUST resin, push excess out with credit card
4: SAND!
5: repeate with adding resin and sanding till weave is filled
It is a more time consuming process, but its much easier to fill the weave putting more layers of only resin on than bondo like some people do, and gives a good surface to sand.
So to end it, I think it depends on the airplane. A warbird I would fiberglass for sure, but a sport plane and similiar, I would use stits cloth.
Jason
This is how i have learned to do it and how i do it, works all the time for me. Only thing to watch is how you mix 2 parts of resin together, if ur ratio is perfect, ur fine, but in case with epoxy resins, if ur bit off, resin will not cure as this has happened to me and i've almost lost my project due to resin being not cured as my mix ratio for that section was off.....
